Application Tuning Cycle 2.0
- User friendly setting of the machine dynamics with included DMG MORI know-how
- Time saving in roughing
- High surface finish during finishing
Downloads
Technical Data
● available
Vertical Machining Center for workpieces up to 4,409 lb and large Y-travel of 27.6 in
High performance & precise vertical milling center for parts up to 1,600 mm length and 2,200 kg!
Horizontal machining center with highest stability, precision and dynamics for super efficient production
Optimum for mass production machining of cylinder heads and cylinder blocks
The most precise 5-axis simultaneous machine within DMG MORI
Traveling column machine of next generation for 5-axis simultaneous machining
Largest DMF working area with 6 m travel
The next Era of Metal Additive Manufacturing!
Hybrid Additive Manufacturing: Building, repairing and coating of high value metal parts up to 4,409 lbs.
5-axis ULTRASONIC precision machining of hard-brittle materials
High performance & precise vertical milling center for parts up to 78.7 in. length and 6613.9 lbs.!
ULTRASONIC 20 linear - the most precise 5-axis simultaneous machine within DMG MORI
High performance & rigid vertical milling center with X-axis stroke 1100 mm for workpiece up to even 1700 kg!
Additional exclusive content:
